Buscar temas sin respuesta | Ver temas activos Fecha actual 24 Ene 2019, 10:52
Responder al tema  [ 453 mensajes ]  Ir a página 1, 2, 3, 4, 5 ... 23  Siguiente
 [ROM][4.2.2][JDQ39E]C-ROMMIX V29.1 & C-ROM V10 [HALO]estable
Nota [ROM][4.2.2][JDQ39E]C-ROMMIX V29.1 & C-ROM V10 [HALO]estable
He incluido la ROM C-ROM que es una versión experimental sin touch wind
V29.1 & V10 (estable):
http://www.c-rom.biz/thread-c-rom-mix-c ... ble-7.html
changelot:
Recommend trying the .5x transition speeds located in Developer options.
Alot Off HALO Fixes New Style And More.
Fix for third party installing with HALO active
Fix misspelling of getLteSignalStrenght.
Add permission that allows cancelling notifications from other apps.
Notification cancellation fixes
Validate restored file paths against their nominal domain
Ensure install-during-restore is like install-then-restore
Add a delimiter between scheme and host
libdrm: fix bad strncpy / snprintf calls
Try to fix null window errors when hangling home action
Revert ram bar show GB commits
Fix NPE when switching signal status style.
Fix requery behaviour of MemoryCursor.
Avoid adding FORWARD_LOCK flag to an updated system app
Fix deadlock of WebViewCoreThread
Add additional Method that check whether a table is empty or not
New Event: ACTION_NEW_OUTGOING_SMS
Also backup profiles file via backup manager.
Fix for NULL pointer exception issue in
QuickSettings: FavContact & UserTile: Open full contact page
Revert "PackageInfo class incorrectly referenced as a struct."
Fixes for clang
Statusbar behavior: New Auto hide options
systemui: Add CONNECTIVITY_INTERNAL permission
Add TouchKey Light Duration Pref
Dont enable Wi-Fi if it's not toggleable in flight mode
Storage Settings: Allow user to trigger a volume rescan
Add Monster pie size
Remove privacy guard fragment in onDestroyView
Refactor SMS Middleware and SMS Send path.
SMS Broadcast result receiver fix
Prompt users Mms can't receive msgs if storage is full
Mms: Fixing possible NPE on contact multiselect when restored from vCard
Many Many More!!!
Instalación:
Sí estas en una jb:
1 mete los archivos en la memoria interna
2 wipe total (data/cache/dalvik)
3 no dice nada de haber format sistem, pero yo siempre lo hago. Lo dejó a vuestra elección.
4 install zip from sd card
Flasheas ROM y luego gapps
5 reinicia
6 disfruta!
Sí no estás en jb:
No dice nada el hilo sobre esto, pero yo aquí aconsejo empezar metiendo por odin una jvu, kernel cf-root y seguir desde el paso 1. Sí en aquí os entra en bucle o se queda pillado, forzais reinicio en recovery y volvéis a instalar sin wipes.
ImagenImagenImagenImagen
Hilo original en xda:
http://forum.xda-developers.com/showthr ... ?t=1925195
A medida que vaya sacando tiempo iré colocando más capturas.
Que la disfrutéis!
Última edición por ohara_14 el 23 Jul 2013, 11:34, editado 25 veces en total
23 Abr 2013, 19:51
Nota Re: [ROM][4.2.2][JDQ39E] C-ROM MIX V17
C-ROM settings
INTERFACE
-carrier label
(aquí puedes cambiar el nombre de la operadora que sale en el panel de notificaciones por el que quieras)
Por alguna razón que desconozco, a mi se me ha quedado transparente esa zona.
-notification drawer style
(estilo del panel de notificaciones. Fondo, transparencia del fondo y de las notificaciones...)
-notification shortcuts
(son unos accesos directos en el panel de notificaciones o en el lock screen)
Esos grises abajo en la captura.
-transparency settings
(nivel de transparencia de la status bar y de la navigation bar. En el escritorio y en el lock screen)
-use alt deafault app picket
(entiendo que se refiere a los iconos de las aplicaciones, pero no estoy seguro)
-ui mode
(aún no lo he investigado)
-hide extras
(sí quieres que se vea el acceso directo a ajustes que hay en el panel de notificaciones, en la pantalla de las baldosas)
-dual panel mode
(Te permite ver los ajustes a doble pantalla)
-lcd density
(dpi)
-recents ram bar
(esa barra de abajo, en la siguiente imagen, que te muestra la RAM usada)
-ctr on/off
(animación al encender y apagar la pantalla)
-low battery warning
(aquí seleccionas el tipo de aviso cuando las batería está baja)
-show wifi network
(para que te muestre el nombre de la red wifi a la que estas conectado)
-power button torch
(no lo he investigado, me suena a linterna, pero no tememos flash en la Cámara que yo sepa)
-wake up on charger
(para que la pantalla se encienda cada vez que enchufas o desenchufas el cargador)
Continuará...
FAQ
- sí no encontráis el calendario, tranquilos. Es por qué no está en la ROM. Lo podéis bajar del play store (Google calendar)
O de aquí:
http://db.tt/7gyAwJup
- Por sí alguno tenéis problemas con la Cámara, aquí os dejo un fix que nos ha traído el amigo dagonz:
http://www.mediafire.com/?v52296pu73isycp
Última edición por ohara_14 el 04 May 2013, 17:25, editado 4 veces en total
23 Abr 2013, 19:54
Grande!!!
Otra mas para probar ;-)
Chinchetaca.
Stranger In A Strange Land
23 Abr 2013, 22:20
¿Qué tal va esta con la batería?
ICS 4.0.3 AOKP Milestone 4
Kernel 3.1.10-IcyGlitch-V14-B6_I9K-T959D tk@Glitch #1
24 Abr 2013, 11:55
Llevo unos días con ella y de momento estoy muy contento. Aunque no he parado de probar kernels, cuando la deje asentarse un poco subiré una captura.
24 Abr 2013, 13:13
Nandroid hecho.
Archivos en la SD.
A flashear!!!
Por cierto, Ohara... no estaría de más un tuto de instalación. Siempre es conveniente (además de un enlace al hilo original, por si las moscas) ;)
24 Abr 2013, 16:16
JulY escribió:
Nandroid hecho.
Archivos en la SD.
A flashear!!!
Odio cocina!
Edito: ahora no me deja editar el primer post desde tapatalk, luego lo intento otra vez.
Olvide poner el proceso de instalación (que viene a ser el de todas las jb), menos mal que estas en todo.
24 Abr 2013, 17:00
Instalada sin contratiempos.
Modificado dpi a 180.
Restaurado apps+datos.
Esta vez voy a dejarla con su rollo samsung. Después de mucho tiempo en stock, me apetece algo de TW y colorido.
Buena y bonita rom. Muy configurable. De momento, entre otras muchas cosas, me ha llamado la atención el tile en scroll al estilo power widget.
Urgando :mrgreen:
24 Abr 2013, 17:32
Urgando :mrgreen:
Mi instalación inicial fue un poco apresurada, comprueba sí te funciona el update me y si tienes la aplicación calendario, por favor.
24 Abr 2013, 17:39
En principio si me funciona el update me.
La app calendario no la ha instalado, no.
Por cierto, en mi móvil, mejor el pez que el semáforo.
24 Abr 2013, 17:44
Solucionado.
Resulta que en la ROM no viene la aplicación calendar.apk
Pues bien, he cogido la app que viene dentro de la supernexus y funciona sin problema. No se sí servirá con la app de cualquier 4.2.2, pero con esta va bien.
Luego lo pongo en el segundo post. Y cuando pille un wifi, subo la app a mi dropbox y pongo el enlace.
24 Abr 2013, 18:34
Yo he bajado la google calendar del play y sin problema.
No lo intentes, ¡HAZLO! O no lo hagas, pero no lo intentes.
24 Abr 2013, 18:55
V18 lista. JulY que a tiempo has flasheado... Jajaja
Cuando tenga un ratin actualizo.
24 Abr 2013, 20:35
Nota Re: [ROM][4.2.2][JDQ39E] C-ROM MIX V18
Ya te digo. Acabo de cenar y veo el muñecajo del update me :lol:
Pues nada. A actualizar :mrgreen:
He hecho sucia y para adentro.
Sin problema. Me gustan las novedades.
Y voy a aguantar semaphore, va bien.
24 Abr 2013, 21:08
Yo con la v17 he probado todos los kernel habidos y por haber y con mucha diferencia fishear y makay se llevan la Palma. Estos dos van igual de bien, pero mucho mejor que los demás
24 Abr 2013, 23:25
Ohara, esta v18, sin ninguna duda, es la mejor 4.2.2 que he llevado. El que me conozca sabe que no lo digo por decir. Rápida, configurable, estable...No he cambiado ni el TW porque va como un tiro.
Gran ROM. Vuelvo a tener un samsung!! :lol:
Imagen Imagen Imagen
25 Abr 2013, 07:26
La verdad es que la flashee por probar y en seguida me engancho.
Me recuerda un poco a la servan, por el cuidado que han puesto en todos los detalles visuales, a ti no?
25 Abr 2013, 09:59
Que grande la servan, como tiraba aquello :smile:
Nos quedaremos por aquí unos días ;-)
25 Abr 2013, 10:52
acabo de instalar esta rom y la verdad que tiene una pinta estupenda. a ver que tal se comporta con el tiempo.
25 Abr 2013, 13:48
que son los ribbons? cual es el hilo original de esta rom? es para ver si hay algún manual o algo para la cantidad de opciones configurables que trae. que pintaka tiene la rom !!!
25 Abr 2013, 15:12
