Buscar temas sin respuesta | Ver temas activos Fecha actual 19 Mar 2019, 03:36
Responder al tema  [ 218 mensajes ]  Ir a página 1, 2, 3, 4, 5 ... 11  Siguiente
 [ROM][KK4.4.4] MackayROM 4.99 Final (16-12-2014)
Nota [ROM][KK4.4.4] MackayROM 4.99 Final (16-12-2014)
Hola!!! gente de la Comunidad Galaxy, traigo esta ROM Mackay con base Cyanogen 11.0 + Kernel Mackay + parches by kasper_h, espero les guste!!!
Full Changelog Mackay ROM 4.99 Final (16-DIC-2014)
Oculto:
hangelog of 4.9.14 - 05-Nov-2014
-CM11.0 codebase of 3-Nov-2014
-TWRP updated to 2.8.1.0
AAll features compared to stock kernel:
Features:
-Build using the Cortax-A8 optimized Linaro 4.7.4 toolchain of Christopher83: http://forum.xda-developers.com/show....php?t=2098133
-O3 optimization
-updated to linux kernel version 3.0.101
-SLQB memory allocator (default, should be slightly faster)
-XZ compression of kernel & initramfs
-395MB RAM
-SIO scheduler
-Added Lagfree governor
-ROW scheduler (tweaked, default scheduler)
-many improvements to IO schedulers in general
-Deadline tuning (thanks to DerTeufel)
-Ondemand tuned (default governor)
-SmartassV2 governor
-Interactive governor (updated to android 3.4 code + fixes)
-Wheatley & Lulzactive governors
-Conservative tuned
-Call volume hack (use “Settings>Mackay Settings”* to set volumes)
-Reduced battery polling interval
-Fast charge (activate through “Settings>Advanced Settings”* or the QuickCharge toggle in MackayROM)
-WiFi PM_FAST mode selection (activate using “Settings>Mackay Settings”*)
-Battery life extender (set through “Settings>Mackay Settings”*)
-CustomVoltage (set using NSTools)
-BLN (can be enabled through “Settings>Mackay Settings”*)
-USB OTG support (needs external power supply)
-1100-1400MHz OC steps
-Custom kernel splash (Thanks to Malcho)
-Updated charging logo to match open charger
-Enabled swap & zram
-Improve memcopy/memmove
-Improve the performance of memcpy and memmove
-Kill task closest in size to memory needed to free
-LOAD_FREQ (4*HZ+61) avoids loadavg Moire
-Entropy tweaks: http://lwn.net/Articles/489734/
-backport CPUIDLE from 3.5
-arm/crypto: Add optimized AES and SHA1 routines
-Unaligned CPU access
-Updates to binder
-Improvements to RWSEM code
-Improvements to binder code
-Improvements to tmpfs
-Added frandom (much faster random number generator)
-Updated to lowmemorykiller with PID whitelist (thanks to stratosk)
-Updated wifi driver to 5.90.195.114
-Updated GPU driver to DDK 1.8@2198402
-Introduce timer slack controller
Link para Descarga:
ROM Mackay 4.99 Final
Basketbuild
GOOGLE APPS
DOWNLOAD LINKS
Google Apps CyanogenMod
Aquí
Instalación:
La primera vez que instalas MackayROM KK4.4 en tu Galaxy S
1. Rootea tu dispositivo e instala Recovery ClockworkMod.
2. Entra en el Recovery utilizando el combo de los 3 botones.
3. Haz una copia de seguridad Nandroid!
4. Wipe data factory reset,wipe cache partition y advanced wipe dalvik cache
5. Instala la ROM desde la sdcard interna mediante el Recovery
6. Importante instalar Gapps
7. A disfrutar!!! ;)
Actualización desde CM7/CM9/CM10/CM10.1/CM10.2
(Si usan el SGS para el día día, hacer un respaldo nuevo de las apps que usen con Titanium, para poder luego recuperar datos y lo que necesiten)
1. Haz una copia de seguridad Nandroid!
2. Wipe data factory reset,wipe cache partition y advanced wipe dalvik cache
3. Instala la ROM desde la sdcard interna mediante el Recovery
4. Importante instalar las Gapps
5. A disfrutar!!! ;)
Actualización desde ROM Mackay KK4.4 anterior
2. Flash ROM
3. Reiniciar (no hace falta wipe nos informa kasper_h)
Screenshot de la ROM
Oculto:
Imagen Imagen Imagen
Oculto:
Oculto:
Imagen Imagen
Kernel:
Makcay Kernel
Semaphore
Mas de Mackay ROM KK4.4
Hilo Original XDA
Agradecer a:
kasper_h
Saludos!!!
:D
No sé cómo explicar..que sólo vivo para vos..que tenemos que ganar..La banda está de fiesta..y nunca te va a abandona!
Racing se metió..adentro de mi corazón..Y nunca va a salir..te voy a seguir hasta el fin..Ni la muerte podrá..detener toda esta pasión!
Última edición por cheto14 el 16 Abr 2015, 17:36, editado 29 veces en total
13 Ene 2014, 22:00
Nota Re: [ROM][KK4.4.2] Mackay ROM 4.1.9 [Beta][i9000]
Espero les guste!! la tengo hace una semana y va de 10!! totalmente fluida, sin FC por el momento!!! en cuanto pueda subo capturas de bateria.
Saludos!! ;)
13 Ene 2014, 22:07
Gracias cheto14,
para ti que llevas ya una semana con esta ROM y posiblemente más en KK 4.4. Me tira "p'atrás" el lanzarme a KK (esta o slimkat) y que tenga aplicaciones necesarias (para mí) no compatibles, ¿usas muchas aplicaciones? me refiero a gestores de correo no google y cosas así.. ¿has tenido problemas con alguna?
14 Ene 2014, 10:49
puntillero escribió:
Gracias cheto14,
Hola puntillero, no uso muchas apps, para correo uso solo gmail, ahi tengo configuradas todas mis cuentas, luego face, twitter, tapatalk, whatsapp, y algunos juegos, por ahora solo no me cierra el GT Racing2, pero va re fluido, se nota la diferencia entre JB y KK
Enviado desde mi GT-I9000 mediante Tapatalk
14 Ene 2014, 12:20
Hola, de todos los kernel que aparecen, cual hay que instalar?
14 Ene 2014, 12:24
Wipes correspondientes y flashea solo la ROM y los Gaaps, ya incluye el Kernel 0.605 de Mackay.
Los otros link son si quieres actualizar el Kernel, el link de Mackay te lleva al 0.607 y 0.608, y el Sema al ultimo.
Yo llevo la ROM sin actualizar kernel y va +10
14 Ene 2014, 13:35
Chincheta a esta súper ROM.
Hay que ver la guerra que aguanta aún el SI ;-)
Nexus four...eando
14 Ene 2014, 14:58
Gracias JulY!!
Es verdad, nunca imagine cuando compre este SGS con 2.2, que iba a dar tanta guerra.
:mrgreen:
14 Ene 2014, 15:48
Perfecto!! Todo funcionando correctamente.
Muchas gracias!!
Por cierto, se puede poner el icono de bateria para que marque el porcentaje?
14 Ene 2014, 17:27
Muchas gracias!!
rowl, lo tienes en Configuración/Interfaz/Barra de estado (Tilde en Mostrar estado de batería)
14 Ene 2014, 18:19
Buenas Cheto, quizas sea un poco cortito, pero , como hago para instalar todo esto?
Hay un link de July muy bueno paso a paso, pero en este me pierdo un poco, muchas gracias
15 Ene 2014, 10:56
Hola el_vels, es facil, te bajas la ROM + los Gaaps, y luego tienes 2 formas:
Puedes hacer Limpia desde Odin con JVU con el Root Pack de la firma de JulY / flasheas ROM Mackay KK y Gaaps
o
Desde la ROM que tienes haces Wipe data factory reset + wipe cache partition + wipe dalvik cache / flasheas ROM Mackay KK y Gaaps
Recorda que puedes hacer un Nandroid por si no te gusta esta ROM para volver.
Quer ROM tienes ahora?
15 Ene 2014, 13:30
2.3.6
I9000XWJW1
2.6.53.7-I9000XWJW5-CL1045879 STRATOSK@SEMAPHORE#SEMAPHORE_2.7.4
GINGERBREAD.XWJW6
Tengo que leerme eso de las wipe, no se como se hace.
15 Ene 2014, 15:52
Muchas gracias por el aporte cheto14
Animaros a los que dudais a dar el salto a Kitkat, esta muy pulida y para mi gusto las roms de esta version estan dando mejor resultado que las 4.3 por lo general. Esta Mackay es una excelente opcion.
Por si alguien no lo sabe os informo un poco de los ultimos kernels Mackay que tienen importantes diferencias entre ellos:
- 0.605 y 0.608 -> 395Mb de RAM (ampliables con bigmen y librerias de kasper_h) y zRAM.
- 0.606 -> Incorpora CMA - 417Mb de RAM (no ampliables con bigmen), sin zRAM. No se debe poner librerias bigmen de kasper_h para evitar conflictos. Puede haber problemas esporadicos de grabacion y reproduccion en HD.
- 0.607 -> Incorpora CMA - 417Mb de RAM (no ampliables con bigmen), con zRAM. No se debe poner librerias bigmen de kasper_h para evitar confilctos. Puede haber problemas esporadicos de grabacion y reproduccion en HD. He leido reportes de peor funcionamiento respecto al 0.606 (aun no se lleva bien el CMA y zRAM al parecer xD).
15 Ene 2014, 17:30
Impecable el detalle de los kernels ATobi, yo por ahora me quede con el 0.605, el cual va de lujo, y no trae problemas con los 720p.
15 Ene 2014, 18:54
el_vels escribió:
2.3.6
I9000XWJW1
GINGERBREAD.XWJW6
el_vels, pasa por Aquí que hay un detalle del menu de CWM y para que sirve cada cosa.
y Aquí tiene un poco de todo para SGS.
15 Ene 2014, 20:13
Yo me la he instalado y va de lujo. Tuve un pequeño problema en la instalación ya que me daba un error de partición de mi móvil, pero lo solucione rápido formateando todo desde el propio recovery.
15 Ene 2014, 20:54
Buenisimo Vazke!
Dejo el consumo de mi bateria que ya tiene +3 años
Imagen Imagen
Casi nada de 3G, algo de 2G, mucho wifi+syncro+brillo70%
y Antutu:
con:
Ajustes/Rendimiento/Procesador: Min a 200 y Max a 1100Mhz
Ajustes/Rendimiento/Planificador: ROW
Ajustes/Rendimiento/Gestion de Memoria: zRam (18%)
15 Ene 2014, 21:25
o
He seguido los pasos desde la ROM, hago los wipw y flasheo.
Va bien
16 Ene 2014, 08:49
Tenía el movil rooteado y permisos de supar usuarios, reinstalo el titanium backup y me dice que no tengo el movil rroteado, que puedo hacer, gracias
El titanium ya me va, no me iba al estar cargando por el puerto usb del movil, eso si, he puesto la opción talkback, esa que hay para ciegos, y no me deja desplazarme por la pantalla, se queda fija y no puedo ir a ajustes y quitar esa opción, pero si te desplazas con dos dedos si te deja.
Última edición por el_vels el 16 Ene 2014, 13:43, editado 2 veces en total
16 Ene 2014, 11:41
